need help with crank/timing sprocket/ pulley
  • need help with crank/timing sprocket/ pulley
    So my crank bolt backed itself out. I went to fix and found the square key was mauled.
    On the big crank festivas is there a piece that goes between the pulley and the crank sprocket? Or does the pully just screw in with the crank bolt?
    I know on the smaller ones there is a lip that the pulley sits on. My sprocket doesn't have that lip.
    Fast....Women are fast
    Quick...Nestle is quick
    I Speak French....in German! lol.
    there should be a beveled washer that sits between the sprocket and pulley, then the pulley, then a plate and then the bolts.
      Thanks. Anyone got the dimensions on the woodruff key/square?
        I don't have the measurements at the moment but I can get them tomorrow or I can send you one if you need it. I have quite a few laying around left over from from swaps.
        WWZD
        Zulu Ministries
          Zanzer how about both?
          I'm going to reproduce one so I have a couple
            No problem. Send me a PM with your shipping info and I'll get one on the way
            WWZD
            Zulu Ministries
              "On the big crank festivas is there a piece that goes between the pulley and the crank sprocket?"
              Hey, what are 'big crank Festivas' and vice versa?
              I am dealing with a similar issue with my '88. See here:
              White '88, 280kmi, Weber 32/36 DGEV Carb with Rocketman Carb Adapter
                they are a larger diameter snout for the pullies to mount to. Mazda fount that in some instances, the smaller snout was snapping off ahead of the oil pump housing, so they beefed it up.
