So tonight I was driving to the bank. When I got to the bank I was using the atm and I heard this rattling. I thought to myself ,crap now I have to pull out more money for parts.
I got over to the gas station popped the hood and saw the air con bracket had rattled loose. I also noticed the drivers side of the engine is shaking pretty hard. When placed in gear and if you let the clutch up the engine will buck 2-3 inches. I'm thinking that's not normal. Your thoughts?
I've read that oil an antifreeze will destroy an engine mounts rubber. My valve cover has been leaking for some time now. Not enough to make me low on oil, I'll drive3000 miles and still I'll have pretty much four Quarts, but just enough to coat the block with a thin film of oil. I know I need to get this fixed, could it be why the mount gave out or is it more likely just because the rubber is 22 years old now.
Now I'm wondering if all that rattling is why my inner tie rods are starting to go. I'm thinking not but stranger things have happened.
