hi guys, first post. went and took a look at a 89 today with the 4 speed. started up after we jumped it but when you really try to give it any gas besides a little to get going she wants to buck and bog. gas gauge was on E so i think that could be a problem but not sure. should i put sea foam or just take it off and bring it in to be cleaned? killed it once but she fired right back up. any ideas, i guess it has been sitting but i cant remember for how long.
89 carb issue
But first, put some gas in the tank and change the fuel filter. If it was low on gas it will have sucked up junk from the bottom of the tank into the filter. Then give it a try.
But yes, I do like Webers.
Josh, post your location. Might be nearby members who can be of assistance.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Josh, post your location. Might be nearby members who can be of assistance. You can go to your name at the top of the page, then click on the "About Me" tab to add your location, and other info you care to add.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
I can't say what's causing the problem but one thing to check for loose, missing, or cracked hoses for vaccum leaks.
I use a hand held vaccum guage for engine diagnosis.
Another thing I do is sparay carb cleaner into the carburetor once a year. Used to be the engine had to be warmed up
but the stuff I have now says spray into cold carburetor.
Hope that helps.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
If you do not have carb rebuilding experience it might be better to replace the carb. There will be a lot more little things that carb needs than just the pump. If that isn't an option you could try pulling the carb off and removing the bowl cover and squirting carb cleaner through every hole you can find. Unscrew anything brass and squirt, then put right back. On any screw that is an adjustment count the turns from where it is at so you can return to the proper setting after cleaning. This isn't kitting or better rebuilding a carb, just some easy stuff to try and get better running for cheap.Reflex paint by Langeman...Lifted...Tow Rig
the hard part is the many vac hoses... the carb itself is easy: 4 nuts, throttle linkage and load comp linkage and fuel line.Trees aren't kind to me...
have several lengths of different thickness' of wire... and PB Blast to soak the vac lines that are difficult to remove.Trees aren't kind to me...
If you are going to overhaual the carb the philips screws on top can be tight and it's easy to ruin the heads. I applied a little penetrating oil and grabbed the heads of the screws tight with big fencing pliers to twist and get started. Another thing I do with tight Philips screws is use the a screw driver tip on a rachet driver for socket wrenches to apply more pressure and levererage so as not to damage the heads. If you get those screws starated while the carb is still on the engine it would be more stable to work on them. Good luck.Last edited by WmWatt; 07-20-2013, 12:31 PM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
alright thanks. i just got it home about an hour ago. shifts awesome and starts just gotta find that sweet spot where it wont bog. but i noticed that it wont always do it. thinking run some seafoam till i get the $ to do it. i have a coworker that will do it for about the price of the kit. now to just bleed the brakes. bleeders look like brand new so i should have it soon. btw, she knocked $50 of because it does need a new battery. pics tomorrow.
