MOOG!
Getting Frustrated...
Chuck
91 GL -Ol' Rusty
93 GL - Lil Red
91 L - Tweetystiva
You can get a replacement oil drain plug or washer or both at low cost. I somehow lost the original copper washer when changing the oil and now have a nylon replacement washer. But you might first want to determine where the oil is leaking from, the plug or the oil pan gasket, or somewhere higher. It can all flow down and drips off the oil pan at the plug, being the lowest point on the engine. If you haven't done that I'd recommend wiping the oil off and looking to see where it leaks from again.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Yup, it's pretty straight forward. Put the car on stands, remove the sway bar, place a jack under the LCA and add a little preload, remove the pinch bolt, drop the LCA, then remove the pivot bolt in the frame rail. That's pretty much the sort version.
Again with the price and PITA to find 12's its almost a relief to hear its suspension components! Once that is complete your car is just that much more new and reliable!1993 GL 5 speed
A few years ago, one of my 88s with 12-inchers had really bad shakes above 40mph. I found that it was a single worn-out tie rod end ball joint. After replacing just that, I could peg the speedo hands-off with no shakes at all.88L black, dailydriver
88LX silver a/c, dailydriver
4 88/89 disassembled
91L green
91GL aqua pwrsteer
92GL red a/c reardmg
1952 Cessna170B floatplane
^ Bummer! Hope it passes!
It always seems that when you really need to do something, something else will keep you from doing it.Dan
Ouch! I know how that feels. I had to go to the hospital because I thought I was giving birth out of my pee hole.:confused1:Originally posted by 88FestivaLX View PostI have a kidney stone and feel like I'm dying
1993 Ford Festiva L blue 170,000 miles
1990 Ford Festiva L Plus white 190,000 Auto, currently waiting to have another engine put in.
1995 Ford F150 XLT black 203,000 miles
2002 Honda CRV silver 180,000 miles
2003 Toyota Rav4 Sport black 94,000 miles
2008 Sym Rv250 dark grey 30,000 miles. My scooter.
1989 Ford Festiva LX black 233,000 miles. Sold to my better half's son.
Mike
Success! Changing them out wasn't bad at all. I'm almost worried bc it was so easy, ha. Took a pain pill and had some beer so I was able to somewhat deal with the kidney stone pain. It's a whole lot tighter now. I still have a little shake, but I think its from messing up my tires with the bad ball joints. By the way, both were toast!
Hehehe
Beer, a pain pill, and then working on a car...maybe the first 2 is why it seemed so easy LOL
Just kidding, glad you hear you get it straightened out :thumbup:
Maybe try rotating the front tires to the back to see if tire wear is the reason for the little shake you still have.Last edited by Zanzer; 08-01-2013, 10:41 AM.
