AC compressor replacement integral or hang-on?
  • AC compressor replacement integral or hang-on?
    Hey gang, I've got a quick easy question. I drove to work this morning in 90 degree heat and my compressor is dying on my 93 5 spd festiva. Called parts store and they said new compressor is over $300. Called salvage yard and they need to know if I have an "integral" or "hang-on" compressor. I wasn't sure which. Car came from factory with AC if that makes a difference. Do you guys know which I should ask for?
    i have an ac on my 1993 and i think it came from the factory that way because the air switch is above the radio on my air conditioned car but let someone else on this forum answer the question more.
      Assuming you're not in bumper to bumper traffic out there, try opening the rear window flaps and see if you don't get enough airflow to make you forget about the AC :wink: . Festivas are really 4-wheeled motorcycles, but it's only in the summer heat that you get the full effect . I made a ~400 mi run yesterday in 95 degree heat, and never wished for AC.
        I've tried and it's still pretty hot. Don't know if it's the humidity here or what. I'm just going to go the yard and check out the compressor and see if it looks same as mine. Haven't found anyone who's heard of integral or hang-on choices.
          if i recalled the junkyard said that the compressor can come off another vehicle besides festiva. check with them
            I went to the "advance auto parts" website , according to their parts lookup a 93 fester could use a SD708 or SD709 compressor ,,, here is a cut and paste of "all vehicles this part fits" from their website for a SD709
            back to top
            1988 - 1996 AEROSTAR
            1988 - 1995 F-250 PICKUP
            1988 - 1995 BRONCO
            1988 - 1995 F-350 PICKUP
            1987 - 1990 BRONCO II
            1990 - 1995 F-450 SUPER DUTY PICKUP
            1988 - 1992 E-150 ECONOLINE
            1988 - 1995 F53 STRIPPED CHASSIS
            1988 - 1992 E-250 ECONOLINE
            1988 F59 STRIPPED CHASSIS
            1988 - 1992 E-350 ECONOLINE
            1988 - 1993 FESTIVA
            1987 - 1990 ESCORT
            1987 - 1993 MUSTANG
            1988 EXP
            1987 - 1997 RANGER
            1991 - 1994 EXPLORER
            1988 - 1991 TEMPO
            1988 - 1995 F-150 PICKUP
            MAZDA back to top
            1993 B2200
            1994 B3000
            1994 B2300
            1994 B4000
            1993 B2600
            1991 - 1994 NAVAJO
            MERCURY back to top
            1987 LYNX
            1988 - 1993 TOPAZ
            here's the list for a SD708
            1988 - 1993 FESTIVA
            heres the list for a 10P13A
            1990 - 1993 FESTIVA
            looks like they all can come V belt or serpentine
            Time to wipe off the grease and look for a manufacturers plate to determine what you have ,,, obviously you want it to be a SD709
            If you need R12 freon I have about 2.5 lbs I'd let go for the eBay price of $15 per lb.
