4 speed to 5 speed
  • 4 speed to 5 speed
    Is this a direct swap or is there more to it?
    Direct swap! Bolt up and go!
    Dan
      ^ boom
      -90 festiva - bp swap "relentless" (thanks matt) aspire swap, pacesetter, underdrive pulley
      -90 festiva - surf blue (undetermined destiny) wanna keep but wifey says noooooooo
        The only thing that you may have an issue with is pulling the axles.
        Do some searching about the swap and read about the easy way to pull axles!
        DO NOT USE FORCE to start things out !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!
        Get the knuckles completely out of the way. Keep axles as straight as possible (they bind if hanging or not straight)
        Start off with gentle pulls and "bump" the axles against the "circlip" ring that holds the axles in. (an expandable metal ring in a groove on axleshft)
        Slowly rotate the axles as you do this. You are feeling for the circlip to "find" the spot where "it" wants to come out.
        You DO NOT want to deform that circlip with force by hitting it really hard against the groove it is in. That can cause the circlip to smash and grow bigger, then the axles can be darn near impossible to get out.
        Just ROTATE axle after each bump like a slide hammer..bump...rotate...bump... rotate. Start off easy, getting a tad harder if need be,
        When the axle finds the spot, it should all of a sudden ... POP! ...out.
        I almost fell over backwards the first time I pulled an axle, it hit the spot and wham, bam IT WAS OUT! Wasnt expecting that.
        The circlip is a ring of steel, about 1/16 thick wire, bent in a circle. Has a gap in it. The key to it all .... is that gap .......
        When it finds the "spot" where it wants to come out, it will compress that wire circlip enough to close up in the groove and ....POP! ... goes the weasel!!!
        Dan
          Drdan, you are not jumping on the message it out gently bandwagon??
          Okay I'll join lol,, I start with two equal pry bars, I get under the shell with both and rock the inner shell from side to side, never entirely letting up on pressure on either bar. Almost all pop right out as the scar on my forehead proves!!
            Yup! I guess I am!
            Do you have a scar shaped like splines? :highly_amused:
            Dan
              We should have a an axle pulling contest at Madness. Whoever can do it the fastest wins a pair of axles.:thumbs_up:
                Ok now another question what's a good price to pay for one?
                  i bought a new axle installed it and went to remove to do my rebuild and when i pulled it it popped right out with little strength but also pulled right out of inner joint and the other part was still in transmission. lol
                  good thing it was under warrantee.
                  www.facebook.com/rhodestiva ;
                  rhodestiva@gmail.com ;
                  '92 Festiva L M/T
                  '93 Festiva GL A/T
                    Yup! I guess I am!
                    The wife says it looks like a scorpion..
                      and then there are those axles that are so stubborn that they will have you thinking about dynamite.
                        What's a fair price to pay for one?
                          $100 - $150 max. Some peeps have sold them as low as $75!
                          Check craigslist around your area.
                          Dan
                            Around here, Festivas and Aspires are quite rare. The Aspire trans that I had cost me $300. The Rio trans I just installed was half that.
                            Check http://www.car-part.com for prices in your area.
                              What happens to the shift indicator light on the dash?
