Black car is a '92 GL auto with factory A/C. I have an '89 factory shop manual and I've printed the '92 wiring diagrams from this site.
My relay has two larger wires and two smaller wires, I figure the larger are the power side and the smaller the switch side.
I've always understood that the first color is the wire color and if there is a / the color after is the stripe.
The larger two on the pigtail are BL/R and BL/BK and if the go straight across, tie into W/BL and Y/BK on the harness. The smaller two on the pigtail are BL/W and Y and tie into BK and BK/W as above. The wires on the harness are all the same size.
The diagram shows the harness to have BK/Y, GN/Y, BK & Y/R. GN/Y goes to the temp sensor, but mine is Y.
The wires going to fan are Y & Y/R which matches the diagram, although the fan pigtail is BL/R & BL/BK.
I've jumped the fan, it works. I tried swapping the relay with a spare, the car wouldn't start (headscratch). Fuse is good too.
I tested both relays, the one on the car is good, the spare is bad (1. resistance)
When it overheated a couple weeks ago, and cracked the radiator, they were running the A/C on the way out to her folks, but not on the way back, when the belt broke.. The pump wasn't froze, just coolant out the pee hole.
