So I've been having a terrible hesitation issue with my 97 Aspire for a few months now. What's happening is if I am driving and say I shift from 1st to 2nd and then press the gas in too fast and too hard, it starts hesitating and sputtering. It does it in all the gears, even at highway speeds. I'll try to post a video later if that would help with a diagnosis. Also if anyone is in the Lancaster area and is free tomorrow around 5 or so, we could meet up and try to figure it out. Thanks!
Aspire hesitation issues
come see meTrees aren't kind to me...
did what i did help at all?Trees aren't kind to me...
i can walk you through it, you just need some specific tools: breaker bar, axle nut socket (29mm), pry bar (short and long). the rest is hand tools.Trees aren't kind to me...
I'm not too sure about technical names of stuff, but Arty took my distributor cap off and there was oil leaking onto the inside of it. He then sprayed it down with something, I didn't get a good look. I also have a cracked part on the inside of the distributor which needs replaced (anyone have a distributor they want to sell?) Arty then reassembled, and I went on my way! All props to Arty!
internal oil seal failure... too bad it's a PITA to repair (almost cheaper to replace than repair)Trees aren't kind to me...
