I just can't figure out the issue I know it's slow I feel it and that is what I am talking about. I put the pedal to the floor and it does that. I might need to upgrade fuel pump that is all I can think of unless the spark plug wires could affect it in that way.
escort gt swap no HP!!
www.facebook.com/rhodestiva ;
rhodestiva@gmail.com ;
'92 Festiva L M/T
'93 Festiva GL A/T
please post compression test numbers if you've ever done one.Trees aren't kind to me...
No I did the clutch swap on my old engine and now on this one it is probably 4 months old.;
'92 Festiva L M/T
'93 Festiva GL A/T
I'll just get festyboy or someone to look at it when I get to FM7.;
'92 Festiva L M/T
'93 Festiva GL A/T
i'll be there...Trees aren't kind to me...
Does your check engine light work properly? Are there any codes? Seems like it's in limp mode1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
Rocketchips!
Bolt-on Weber Carb Adapters!
That was the brake light it's always on.;
'92 Festiva L M/T
'93 Festiva GL A/T
CEL does work I tested it with o2 sensor but I don't have the CEL issue. I will take it to oreillys to get it tested to see if a code shows.;
'92 Festiva L M/T
'93 Festiva GL A/T
Something definitely isn't right...like bobby said you should bury that needle. A b6 will spin it around before yours hits vertical. Love the interior tho, you need nitrous after you figure out what's causing this.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
[QUOTE=Rocketman;611658}Miata BP ecu will not work AFAIK[/QUOTE]
will your car run at all with the miata ECU?;
'92 Festiva L M/T
'93 Festiva GL A/T
He's really gonna like his BP with a TPS,I cant believe it even was drivable?Some people like to read fiction,I prefer to read repair manuals. Weird I know-
The TPS is hooked up in the video but still no power.;
'92 Festiva L M/T
'93 Festiva GL A/T
What letter is on your VAF?2008 Kia Rio- new beater
