Scratching my head
  • Scratching my head
    When I look at a EFI picture in the Haynes manual it shows a evap canister. My 1990 EFI doesn't have one but everything looks connected but I have a few connectors by the brake boost and don't see anywhere to plug them into. Is everything on my car or has someone removed something?
    EDIT: Sorry, I was thinking purge canister solenoid.
    Those plugs by the booster are used for tach, STI, and testing.....they are supposed to be open.
    WWZD
    Zulu Ministries
      According to the picture right next to the ac lines I have 2 bolts but nothing else.
        There should be some vacuum hoses which go into and out of the cannister.
          Good pics will help us help you.
          '93 Green L - ' Tiva
            ^^ x2
            WWZD
            Zulu Ministries
