No, Greg , no pop. Just the sound of it moveing back & forth.
Loose steering
when you installed the energy suspension bashing did you shave them and use through stock brackets or did you use the es brackets on a piece of the plate. if u used the es brackets and plate make sure you get as much caster out of your brackets as possible i had a similar problem with mine and i had the bracket slid back ,moving it forward got read of the bump Stear and shake.
not sure if this is your problem just thrown it out there.
