My Haynes manual says 60 ft/lbs of torque for the head bolts. Can some verify that? The specs just seem low for the main engine components.
B3 torque specs
It's correct. If you install ARP studs, it would be much higher, like 80 or 90 ft-lbs.Last edited by TominMO; 08-28-2013, 08:04 PM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
yea it's 60...arp bolts say 80, but guys on cp.com have reported the head cracks with that much torque on the bolts. Don't know or understand why but it was a big deal to them when I built my BP.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
i run 70 when re-installing a head (set it and forget it)Trees aren't kind to me...
I've done the headgasket on the B3 a few times. It was recommended to do 20-40-60ft/lbs. Do the spiraling out pattern, all at 20, then again for 40, and 60.Last edited by crazyrog17; 08-28-2013, 11:11 PM.-Zack
