Ok, I have yet to get the idler pulley stuff, and the system hasn't been pressure tested, or put under a vaccume.
But I would figure if there was no pressure on the a/c system, it would kick the clutch on regardless to try and build the pressure up.
But no, I hit the A/C button with the blower on, and the light comes on. But I hear no click of the a/c clutch, and I can spin the pulley, but the clutch doesn't move.
I have even tried it with the engine running, but nothing.
So to rule out the clutch being faulty, I jumped the clutch wire directly to the battery. Aside from some big bright sparks, the clutch clicked. So the clutch is fine.
I also thought the radiator fan ran all the time when the a/c was on? Again mine doesn't when the button is pushed.
I have already checked all the wiring, every single connector is hooked up.
EDIT:
Ok after digging a little more around here, I see that the compressor won't engage if the sensor doesn't pick up enough pressure in the system.
Well then how the hell are you supposed to charge a completely dry system?
EDIT:
