Steering Knuckle Rebuild
  • #16
    Originally posted by 1990new View Post
    Inserting the outer bearing in the knuckle and then pressing in the outer seal first made it much easier.
    Press in inner and outer races, bolt on the rotor, press the hub thru the outer bearing already in the knuckle, put the spacer on, drop in the inner bearing and press it on, press in the inner seal. Easy as pie.
    Thats the way to do it! Couldnt find a way to put it in words myself
    1991 Mercury Capri XR2 "GTXR2" BPT Swapped AWD Conversion
    Rocketchips!
    Bolt-on Weber Carb Adapters!
