aint never gonna change it!!!!!! (oil)
  • aint never gonna change it!!!!!! (oil)
    well it is that time again....
    I need to change my oil but I am sure all i will do is make my hla's start that loud racket again.
    see this is what happens .
    new oil = loud tapping
    old oil = runs smooth and quiet.
    so i am not changing it just the filter and topping it up.
    wish me luck.
    shayne
    just try 15W40 oil
      I have tried 15 kinds of oils and weights.
      new oil they get noisy.
      even with 0 30 winter oil.
        try replacing the HLAs
          0w30 winter oil is very thin ,makes for easier starting in very cold temps ,no wonder they are noisy
          HD2500 Duramax Chevy
          Z28 LS1 power 500 +
            Bassman ,I just found a thread from Aug 05' where you were having this same problem ,I am surprised you are still fighting this problem .
            Z28 LS1 power 500 +
              ya same problem.
              but it is not a prob if i never change the oil.
              I have a smashed donar car with only 40 000 k on it so if i am going to change anything i will swap the engine.
              mine has 170 000 k.
              as i see it if i at least put in a new filter and 1 litre of fresh oil i am not hurting anything that bad??
              plus i dont have alot of time right now to start fixing hla problems.
              or should i use synthetic and just change filters ??
              shayne
                Actually, the oil would only be considered "thin" at neg 35C. At room temp some 0w30s are thicker than 10w30s.
                www.dantheoilman.com
                Go ahead and ask me why
