Are these the headlight relays?
  • Are these the headlight relays?
    Need help identifying these? Headlight relays? They are right behind the driver heAdlight. Tia
    Sent from Kingston Ga from my hillbilly handheld
    90 festy with 92 FI motor. Digital camo paint. BHAF. short throw. currently 47 MPGs
    The '92 schematic I have shows 3 relays, though my car only has 2 also. The shcematic calls them out as being for the A/C. One a wide-open-throttle relay (to shut off the A/C), one an A/C relay, and one a condenser fan relay. I have not yet had to trace them anywhere and like I said, I also only have 2. One of mine had been rubbing the battery tray and was pretty corroded actually.
    -toast
      I have replaced the relays. I have cleaned the ground by the battery and checked the fuses. Also replaced one blown bulb. Still nothing. Now my blinkers don't work so I'm leaning towards the headlight switch. Unless anybody knows of what else to check I'm going to start pulling the switch AMD try to find another
        In your headlight connectors , do you have 12v coming in? you can check that with a test-light , then you can see if the ground is good with a multi-meter set to ohms.
