I bought a new 90 L Plus today.
The CL ad said it overheated and the engine was seized. It most definitely is not seized. It runs pretty good, actually.
26X,XXX miles
Except a few things:
very low idle/stumble/miss
The idle speed is super low. I checked the ignition parts and the wires, cap, and rotor were all crusty with corrosion. I replaced all of those along with plugs I had sitting on the shelf. Not new components, but they show hardly any wear.
Still idles/missing a low speed. The engine revs just fine. Sounds good with no knocks or rattles and revs up quick.
coolant fountain
I changed the radiator cap as well because the old one was clumped with what looked like red dirt. I'll assume its rust. The whole cooling system is full of it and the engine compartment has a coat of coolant rust from when the bypass hose blew.
While running, and barely even hot (the temp gauge hadn't moved, if it works), water was spewing out of my new rad cap. I took it off and ran the engine without it and a bubbly fountain of brown cold water came out of the radiator. What is this an indication of? I know I need to do a coolant flush. Badly. Clogged/stuck thermostat?
gauges
As mentioned, I suspect that the temp and fuel gauges may not work. Neither one moved at all. The Meter fuse is good.
That's all I can think of for now, but here's a few positives:
A/C blows ice cold and strong
Relatively clean in and out
Still has owners manual and original dealer packet
Factory radio
Tach cluster
I scored it for $180 + $50 in gas
26X,XXX miles
coolant fountain
gauges
Factory radio
Tach cluster
