Ok so I recently bought a 1998 three door ford festiva and I love her! Noticed right indicator blinking at double time so changed the bulbs today, however then noticed that instead of the bulb needing replacement it must be something else - the rear indicator works fine provided the brakes aren't being pressed, soon as the brake is pressed the indicator stops flashing and the brake light starts flashing instead. Not ideal.
I can do the basics mechanically but I don't want to start messing around with the wires when I don't really know what I'm doing - I'm guessing though it's obviously a connector or perhaps a fuse issue and if I can fix it myself I will... Any ideas or suggestions would be great, thanks!
