What hooks here?
  • What hooks here?
    ImageUploadedByTapatalk1378693640.785964.jpgImageUploadedByTapatalk1378693652.754696.jpg
    Also there's a small line off the intake where does it hook into?
    That's your IAC, or idle air control solenoid. A black, molded hose fits from there to the intake. It is what bypasses the throttle body to allow some computer adjustment of the engine speed at idle.
    -Zack
      Ok ill look around.
      What about the small hose right where the heater core hooks to the line off the water pump?
      I should have took pictures....
        The coolant bypass tube wraps around the block and goes to the heater core hose, and the small hose there goes to the bottom of the throttle body. Another small hose connects the throttle body to the IAC. If I could better understand what you're looking for I could take pictures
        -Zack
          Anybody? The only hose that I can see might hook up there is one that comes off the water pump outlet.
            I've got a hose coming off the bottom of the intake on the back side of the IAC. But then I have a hose off the coolant bypass and a open nipple on the IAC. Do those hook together?
