Are the two bigger hoses that come out of the throttle body coolant hoses? 93 Festiva GL
Throttle Body Hoses
Chobob, the brake booster hose is on the intake mani, and the IAC hose that goes to the "silver" thing is also on the intake mani.
The two larger hoses on the bottom of the TB are coolant hoses. As I recall, they are there to help keep the throttle from sticking at extreme temperatures... and I have often bypassed them. Who wants warmer intake air?~Nate
Current cars:
FOTY 2008 winner!
Screen shot 2013-09-10 at 7.31.47 PM.jpgScreen shot 2013-09-10 at 7.31.31 PM.jpgThe ones under the TB are the ones I replaced, I used heater hose. It was confusing to me cause I took a whole bunch of stuff off, and it seemed weird to me to hook coolant lines to the throttle body, I kept thinking, I am going to end up flooding my engine with water. Here are some pics. Thanks for the replyOriginally posted by skeeters_keeper View PostChobob, the brake booster hose is on the intake mani, and the IAC hose that goes to the "silver" thing is also on the intake mani.
The two larger hoses on the bottom of the TB are coolant hoses. As I recall, they are there to help keep the throttle from sticking at extreme temperatures... and I have often bypassed them. Who wants warmer intake air?93 Festiva GL
It is the first time I took the throttle body off, so It seemed strange to me that coolant lines would run to it since it has to do with the air flow and it is not a radiator. That is why I had to ask for help, because I didn't know.Last edited by Breedlove; 09-10-2013, 07:49 PM.93 Festiva GL
Yep, you got it right!~Nate
Current cars:
FOTY 2008 winner!
I know where he is coming from on that... On a festiva I've messed with it enough times to know it like that back of my hand, but when I was installing the engine in my wife's Focus it was a little harrowing because there are 4 ports of the same size on the back of the manifold. Two are coolant ports, two are vacuum ports. Hook those up wrong and you'll get exactly what he was worried about. So I definitely get where you are coming from. Fortunately for Festivas, both hoses under the throttle body are coolant lines, and the direction of flow doesn't really even matter, so as long as you have one hose to each port (or bypass them completely like Nate) you are good to go!No festiva for me ATM...
Originally posted by koRnhead View PostRight. I understand that.....but think about it. You just took coolant hoses off ur TB. And your car didnt flood or anything else. So why would it start now, unless you broke something in the process?Last edited by Breedlove; 09-12-2013, 06:49 PM.93 Festiva GL
Originally posted by htchbck View PostI know where he is coming from on that... On a festiva I've messed with it enough times to know it like that back of my hand, but when I was installing the engine in my wife's Focus it was a little harrowing because there are 4 ports of the same size on the back of the manifold. Two are coolant ports, two are vacuum ports. Hook those up wrong and you'll get exactly what he was worried about. So I definitely get where you are coming from. Fortunately for Festivas, both hoses under the throttle body are coolant lines, and the direction of flow doesn't really even matter, so as long as you have one hose to each port (or bypass them completely like Nate) you are good to go!93 Festiva GL
This is an old trick we used to do on Mustangs and pretty much any Ford with the coolant heated EGR plate.
When I got my first Festiva and was doing some work under the hood I spotted the 2 coolant lines running to the throttle body and my reaction was "well well, what have we here? This looks very familiar". I then removed one of the hoses completely and connected the other to the nipple on the hard pipe to bypass the TB, just like on all the other Fords I had in the past. I've done this to at least 6 Festivas since (the latest being last night).
And I have a throttle body in my shop that was removed because the coolant was slowly corroding away the aluminum between the water jacket and throttle body plenum. If left like this it would have slowly worked it's way through and the engine would have been drawing coolant down the intake tract at some point.
Originally posted by Zanzer View PostThis is an old trick we used to do on Mustangs and pretty much any Ford with the coolant heated EGR plate.
And I have a throttle body in my shop that was removed because the coolant was slowly corroding away the aluminum between the water jacket and throttle body plenum. If left like this it would have slowly worked it's way through and the engine would have been drawing coolant down the intake tract at some point.93 Festiva GL
^^ Right, that didn't cause the corrosion. That mod is done so the coolant now bypasses the TB so it doesn't heat the intake air charge anymore. If you connect the 2 outlets (the ones that feed coolant to the TB) on the coolant tubes with one piece of hose you're just looping the coolant back to the tubes and the TB is now operating dry. Coolant in the TB (factory setup with hoses sending coolant to the TB to heat it) is what caused the corrosion I found on the aforementioned TB.
Edit: I suppose you could also just delete the 2 outlets with a couple of rubber caps and clamps. I've just found it easier to loop it back since the shorter piece of hose works pretty well for this and it's already thereLast edited by Zanzer; 09-12-2013, 09:13 PM.
