Im going through my haynes manuel, trying to diagnose my 91 festiva, they are talking about blink codes. Does anyone know if this works
Codes, diagnostics 91 Festiva
Yup it does. I keep a jump wire with a spade terminal on each end in my glove box1963 Fairlane - future NSS drag car
I permanently stuck a spade terminal in the black STI one-wire plug, and then use a wire with alligator clips on both ends to connect it to the motor as the ground. Then read the CEL's blink codes. No need to deal with the STO-and-ground with voltmeter technique.Last edited by TominMO; 09-17-2013, 05:50 AM.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
This info is in your Haynes manual, page 6-13 in my version.Originally posted by Jblair View PostI now have my jumper wire i will carry. Code 2 cp sensor, where and what does it look like.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
