Maybe I should have rented a compression tester before doing a tune-up, but I had high hopes/wishfully thought replacing a few wear items would afford me a reliable car. Unfortunately, that doesn't seem to be the case.
So, here's a video- complete with commentary. Engine runs smooth as butter at 500rpms warm. Doesn't have excessive amounts of gas leaking into the coolant that I can see. Also, don't notice any coolant loss.
I just need someone to burst my bubble. I see a combination of rings, valve stem and probably head gasket or cracked head. Engine needs rebuild and car's frame is tweaked. What would you do?
Thanks in advance.
Thanks in advance.
