The Festerossa, died to today, while over 100 miles from home.. need help.. I started the 93 festiva L, went to back up and the car went completely dead. No dash lights, no sounds from the starter, no head lights or horn. However when turning on the head lights (only the bright lights ever worked) I heard an electrical buzzing sound from around the passenger front wheel well. Not sure where it was coming from, almost sounded like under the air filter. never noticed the sound before.
may or may not have to do with this problem.. but since I had the car only the bright lights worked. a couple times very recently, while driving the head light turned off, then back on. only did it twice, but it was within a few days of not starting. The car has always started first time right away. the previous owner towed it behind his motor home, so I have a trailer light wire harness wired into place. I checked all the wires visually with no obvious signs of problems.
I checked the battery, and cleaned the posts and terminals. the door buzzer, buzzed but sounded very weak.
I checked the interior fuses. I looked at the wire jumper fuses near the battery, they appear ok. I will get a meter on them.
Any thoughts to begin looking or ways to trouble shoot would be greatly appreciated.
Fuses? Ignition? any thoughts?
Thanks
David
Thanks
David
