Where do the shifter busings go?
  • Where do the shifter busings go?
    I have pulled out the shifter rod between the shifter and the transmission. There is a noticeable gab in the linkage where a bushing ought to be. I can't figure out how to take this assembly apart to put the new busing on. How does this come apart?
    Where do the other 3 bushings go? Nothing is jumping out at me....
    1991 Festiva GL
    Nevermind!
    Found this: http://www.fordfestiva.com/forums/sh...ifter+bushings
    Guess I have to cut it out and do it right!
    1991 Festiva GL
      I just did mine.. I got the new short shifter in yesterday and its going in this weekend.. if I ever figure out the headlamp prblem.. World of difference.. Orlando? I am in Lakeland.. get it running may have to share tips...
        I'm in the daytona area as well and just did shifter bushings soon to install the short throw as well in my 93 L.
          This rubber boot (pic borrowed):IMG_1526.jpg is completely torn in half and demolished. I called the local auto parts stores and they can't find it. Thoughts? Is there a cheap way I can fix this?
          Should I just get a new shift assembly from fourgreen and stop worrying about bushings and boots and old rubber?
          1991 Festiva GL
            Where did you get a new shifter from?
            1991 Festiva GL
              The Kia part number for the boot is KKY0146090.
              You will also need the ball seat KKY0146086 if they have any left.
              I had a short shifter, but I didn't like it because the shaft was too short.
              More effort is required to shift, even though the shifts are shorter. A heavy shift knob helps.
                Found it from kiapartsmichigan.com for $5 shipped. Hopefully they are legit and will actually ship it to me
                1991 Festiva GL
                  Didn't feel like cutting up the shift linkage so instead I chopped up the NAPA bushing I had on hand, then epoxied it in place. Cheap but effective lol
                  1991 Festiva GL
                    Welcome. Haven't seen ya'll on the fourm. Theres a lot of members from Fl. on here. i'm in Tampa. we should have a mini-meet.
                    '93 Green L - ' Tiva
                      I got it off ebay, honda civic short shifter , 10 bucks with shipping...
                        Tampa! I commute from Lakeland to Henderson ave on the far side if the airport everyday 90 mikes round trip.. heck yes..
                          i just bought a 1991 festiva my question is i have an automatic and the bushings are bad and cant find new ones for it where can i go to get new ones??
                            I have never even driven a Festy with a standard shifter with good bushings. lol
                            The bushings that were gone on mine, were the ones on the end of the shifter itself, so I just bought a Civic shortshifter on ebay since the bushings are built into those.
                            Followed the guide on how to install it, so I bought a nut, bolt, and a few washers, cut a coil off the spring so the larger pivot ball will fit, been driving on it almost a year now if it hasn't already been a year. I can't remember at all what it feels like to use the standard shifter anymore.
                            Only slight problem is the boot, too short for the old shifter boot. But find a Auto/Full console and get any shortshifter boot off ebay.
                            My setup, EGT Shift knob, Festy Auto Console, with the Civic shortshifter, with ebay suede shifter boot.
                            I guess is you have long legs, and short arms you would hate the shortshifter, but I think it is just fine, and doesn't make it look like an old truck where the shifter is like 10 feet long. lol
                            Automatic doesn't use bushings for the shifter to my knowledge, it uses a cable, so your cable is probably bad or just needs adjusting.
                              Torque, what color is the stitching on the shifter boot? Blue, gray or white?
