I lost the lower one today on the road. I cant find my spares. Can someone give me a measurement of the upper and lower bolts? I cant get at the other side currently. NOT SLIDERS...The ones one uses to put the caliper onto the bracket. Its shiny zinc coated, number 10 on the head, 12mm head size.
Caliper bracket bolt lengths festiva
How are bolt lenths measured?
Top bolt 2.75" (7 cm) from under head to end of bolt, 3 1/8" (7.9cm) total length
Bottom bolt 2 3/16" (5.5cm) from under head to end of bolt, 2.5" (6.3cm) total length.
Bolts off original 1989 stock caliper.Last edited by WmWatt; 09-30-2013, 08:11 AM.Original owner of silver grey carburetted 1989 Festiva. 105k km as of June 2006. 140k km as of June 2021.
Thanks i did finally search down a thrrad with a pic and the looked 3. And 2.5 but if they are too long it would do me no good. That database in progress definately neefd these items1993 GL 5 speed
Bolts are measured from under the head.Originally posted by WmWatt View PostHow are bolt lenths measured?
Bolts off original 1989 stock caliper.-------------------------------------------------------------------------------------------
My Musica! Click me!
its a 55mm bolt, which no one has but ones w/threads all the way down, and no flange--had to use a washer too.. Hope it works for me. BTW i swiped lots of aspire and kia bolts along the way but they are all longer. People seeing this need to bag and tag, dont assume that because spindles and calipers are no fabbing needed to work on a older car the fasteners have any chance of being the same lol1993 GL 5 speed
Got a set if you need them.'93 Blue 5spd 230K(down for clutch and overall maintanence)
