AC Installation question on a 93 GL
  • AC Installation question on a 93 GL
    Hello. I have been looking (with little success) for a complete AC setup for a 1993 GL automatic. I think I may have finally found an AC setup, but it's from a 91. I've heard that the 93's use a unique pulley. Is this true? If so, is there a work around? Finally, maybe this should be a second thread, but can an Aspire AC system be made to work in a Festiva? Any feedback is greatly appreciated. Thanks.
    "If you can count your money, you don't have a billion dollars." - J. Paul Getty (1892-1976)
    the '93 pulley is different. I bought a '91 L with AC and swapped in the old motor from my '93 and the bolt holes for the pulley's are way different. I'm still looking for a '93 with AC to pull the double pulley from, but for now I just have the setup there, with no pulley/belt going to the compressor... you might be able to swap out the whole crankshaft timing belt sprocket. I haven't tried that yet, but if you can that would allow the '93 motor to use the older style pulleys.
    No festiva for me ATM...
