Rotors won't come off
  • Rotors won't come off
    I currently have taken off the caliper and retaining screws from my 97 aspire and i still can't get the rotor off. Any help at all? Here's a picture of where im at ccurrently
    I see no pic. If you have the screws (2) out and the caliper out of the way, then the only thing that can be keeping it of is corrosion between the hub and the rotor. Make sure the vehicle is supported well and take a hammer (rubber mallet is best) and start tapping the surface that the brake pad clamps on, working your way around the rotor, basically keep tapping all around until it comes off. Good luck
      Yeah sorry the pic must not have uploaded, so now its a matter of force?
        A few good smacks and a little PB should loosen it right up, unless its unusually rusted in place!
        ~Nate
        Current cars:
        FOTY 2008 winner!
          I've had some rotors rusted so bad that hit them so hard with a sledge the rotor breaks in half
            I've had the same problem, this is a good solution. PB those bad boys and let them sit a few hours. (PB Blaster)
            88L - Awaiting bigger and better things
            92L - Dead and needs love - was DD
            91 - Shell with title
            92GL - receiving B8 Swap and will be DD
              I've teased the rotor in a circle around the hub with heat, pops loose.
              Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
                impact driver knocked the screws loose for me.
                www.facebook.com/rhodestiva ;
                rhodestiva@gmail.com ;
                '92 Festiva L M/T
                '93 Festiva GL A/T
                  Finally got them! Pb did the trick in a few minutes! Pics later!
                    2nd that!^ good to hear you finally got em off!!
                    -1991 L 238k AC/Cruise Josh's future DD from neanderpaul, the clean slate!
                    -1991 GL 171k AC/Rust free Jake's future DD (thanks kevin!)
                    -1993 L B6T swapped auto(thanks rob!) 88k was 123whp 15.8 at 87mph currently undergoing surgery
                    -1989 LX crazy project car you'll all see one day! (hopefully fm8 )
                    Have one hydro g and xr2 mid shaft for sale super cheap! PM me!
                    we have owned 10 of these cars to date and we're only 20 hahah.. call it an obsession!
                      Coolness!
                        PB is the bestestes!!!
                          Updated my car's main thread, you can check it out here http://www.fordfestiva.com/forums/sh...-s-Widow-Maker
