Over the summer i ran into a slight problem that is turning out to be a bit worse than i thought at first. On my 97 aspire, the clutch cable runs into the firewall and there it meets the pedal assembly at a bracket. This bracket is what keeps the proper tension on the cable to keep it on the pedal assembly. The problem lies in the fact that Ford thought that a small weld on either side of this bracket would withstand years of pressure from the human foot. Over the summer both of those tiny little dots called welds broke and that left me no other option but to rig it up by drilling some holes and bolting it in place. It was a good temporary fix, but for some reason the pedal keeps losing pressure and i have to keep tightening up the clutch cable. Lately I've realized that the pedal has felt a little weird, so i took a look at it today and saw that the pedal assembly on the clutch side is bending a bit.
Guys, i need a solution, should i buy another pedal assembly and hope for the best in that the events don't repeat themselves, or is there a stronger solution i.e. aftermarket pedal assembly made of tougher material? I can try to upload pics later if needed, and i thank you all for all input!
