I have a 1989 Festiva L I need the two plastic bushings that go in the gear shift. Does anyone know where to get them? Thanks
shifter problems
Hiya granny. The better to see you with.
Do you mean the upper ball seal and lower ball seat ? underneath the spring?
or the bushings that are at either end of the bolt that attaches the shift rod to the transmission? Please identify the parts you need on this diagram.Last edited by bravekozak; 10-22-2013, 08:25 PM.
granny, the better to eat you with. You missed the big buy.
I only have an upper ball seal left. $1.50 + shipping at cost from Lewiston. PM me your address if interested. The lower ball seat will have to be purchased from Four Green. It is 87 cents + shipping from Korea. Is yours cracked? Mine was. What a difference when I replaced it!Last edited by bravekozak; 10-23-2013, 06:37 AM.
It is supposed to be split in one place. If it's cracked into more than once piece or in more than one place there's an issue. Otherwise it's fine.Last edited by sketchman; 10-23-2013, 08:41 AM.Any difference that makes no difference is no difference.
