I have an 89 Festiva L with just over 50k on it. The other day I noticed I lost 3rd, 4th, and Reverse. Thus I jacked it up and found that the Shifter Support Bracket piece( Im not sure if thats the correct term, but its the piece that keeps the stick shift upright and I believe lined up so all the gears engage correctly) was broken/rotted totally away. Would this piece affect how the car engages the 3 gears I lost? I think it does anyhow and I cannot find a part anywhere here in Central NY. Any info would be greatly appreciated as this is my only car to get back and forth to our firestation as well as work.
P.S. The piece Im referring to is mounted by 4 nuts to the frame accessible under the shifter boot.
VinlandFrost :twisted:
