My 88 LX has been ticking for quite some time now. Last week, I adjusted the rockers to 0.012 inches as it says under the hood, but the engine's still noisy. It's probably because of wear or lack of maintenance. So, I was wondering, are any of the EFI Festiva or Aspire heads "backwards-compatible" with the Carbureted Festiva setup or can I only use 88-89 heads? I've been looking through the forum posts, and some people say yes and some say no. I've heard that the efi heads should work with the carburetor manifold and that they have the access plate for a mechanical fuel pump, with the required lobe on the camshaft. So in theory it would work, but other people have said that an inline fuel pump with a regulator is required, so I'm not so sure any more. Any input would be greatly appreciated.
Thank you.
Thank you.
