I have a 93 festiva. Extremely high idle.I believe i have narrowed it down to an issue with the idle air control valve.I have swapped it out with a different one with the same high idle issue remaining.I can clamp the hose on either side of the iac to achieve proper idle.If i unplug it, it idles back but runs rough.Would anyone know if their are any other sensors ect in vehicle that could send an improper signal to the iac thru the ecm?
iac problem
Tags: None
Originally posted by htchbck View PostThere is an idle adjustment screw under a rubber plug on top of the throttle body. Clockwise lowers idle, counterclockwise raises idle.
The idle set screw is under the throttle cable arm. It has an 8mm hex, on a small threaded piece. In the end of the threaded piece is a spot for an Allen wrench. You must first loosen the hex with a wrench, then adjust the Allen, then lock it back down with the wrench.-Greg
Redneck Engineer
FOTY - '09
Finally got my racing motor issue figured out .Bad engine wiring harness.
Originally posted by eurotiva View Post^not to step on any toes, but that is incorrect. That is the idle mixture screw. Although it will raise and lower your idle, it will cause other effects under different driving conditions.
if you've been adjusting your idle with that allen screw, you should also be moving the TPS to compensate.Trees aren't kind to me...
^no toes squished
Im glad you clarified that. My case is different, because I don't even run a tps-Greg
Redneck Engineer
FOTY - '09
density based system i take it?Trees aren't kind to me...
Originally posted by FestYboy View Postdensity based system i take it?-Greg
Redneck Engineer
FOTY - '09
