any thoughts?? this is like my 7th festy and none felt crazy soft like this, its dangerous ??????????????????? thanks
89' that feels like it wants to roll over at like 3mph??? thoughts?
^ This!Originally posted by 1chrisapple View Postbiggest issue is probably struts worn out and also check the sway bar isn't broke. never seen it but it's possible
Also check the LCA's and ball joint, and check for play in front bearings by lifting car off the wheels and grabbing tire and push/pull sideways and up and down to see if if it is tight or has excesive play.Last edited by drddan; 11-01-2013, 11:42 PM.Dan
