97 Aspire Brake and Clutch Pedal Assembly Removal
  • 97 Aspire Brake and Clutch Pedal Assembly Removal
    I just received my Clutch and Brake Pedal assembly in the mail from 1990new (Thanks so much man, this thing is perfect!) and I was wondering if anyone could point me toward, or give me a write up on how to remove and install this assembly? Any help is appreciated! Thanks so much!
    Seeing as you physically have the swap parts on hand presumably you can reverse engineer how to remove the old and install the new by looking at all the holes and mounting brackets. I've had the clutch pedal off on a Festy before and it is secured to a shaft common with the brake pedal. It may be you only have to change/add pedals and not have to swap out the whole shebang. Get under the dash with a flashlight and compare everything before you start.
    By the way; good luck!
      The individual pedals don't come off the bracket, the bracket needs mounted.
      2008 Kia Rio- new beater
      1993 Festiva- Fiona, DD
      1997 Aspire- Babyspire, DD
      1994 Aspire - Project Kiazord
      1994 Aspire- Crustyspire, RIP
