So long story short... the wires that run along the drivers floor rubbed on the floor and melted together. So I repaired all the wiring there. Now here's where the issues come in to play...
1) Turn signals don't work. Emergency blinkers work though.
2) I turn on the headlights with the car running and the buzzer comes on (high and low beams work)
All other lights work fine and car runs fine after the meltdown.
Im guessing that the issue is in the turn signal switch itself. Is there anything else I should check out that I'm overlooking? Is it a PITA to change the turn signal switch out?
Thanks!
Thanks!
