All the time belts worked fine, and did not cause any complaints.
But a few days ago, stopped to close the driver's belt.
I reached the door, checked the micro switch on the castle - it's OK.
Then I removed the side panel where the motor belt - there are also fine.
Checked the connector block that is under the seat, and smeared it with a special spray - and nothing has changed.
Please note that the fuse is normal, and the passenger belt works perfectly.
I tried to manually move the lock to different distances, and when you open the door - he was always properly shifted to the "open" position.
Also a few times was that the belt is properly closed (with the ignition on and the door is closed). But I have not found a pattern.
What do you think about this?
The impression is that the belt-control unit does not see the running ignition, and only for the driver's seat belt.
