92 GL (automatic), 113,XXX miles.
I would like to start a new thread, to replace my previous thread: http://www.fordfestiva.com/forums/sh...A-New-Oil-Pump
Blew the upper radiator hose, engine overheated. Soon after I realized oil mixing into the coolant. Drove it to work for a few days out of necessity (9 miles) until I could get another vehicle.
Now that I have another car, I can take my time to work through this and hopefully get my Festiva back on the road someday. Work will be crazy busy until the end of the year, so I won't be able to work on it much until January or later. I miss my Festy!
I am thinking I can flush it out a little at a time, until I can do a thorough back-flush out in the driveway. I plan to install a new radiator, along with new hoses ect., so I would like to flush the system well before contaminating the new radiator. Then I will need to get some antifreeze into the block, to protect everything from freeze damage this winter.
The latest: drained the radiator
Rinsed the radiator twice, then filled the system with water to flush the entire system. With the fan unplugged, the thermostat opened and then the heater started blowing cold air a couple minutes later. Is this normal?
What is the best way to flush this crap out?
