Ever since I bought had this Festy, which as been for about 16 months now, it has always sounded like this, but has always ran fine.
I know it is almost impossible for any of you to be able to pinpoint without being able to listen to it yourself in person. I originally put it off since it sounded normal, but hearing other people's B3s running at Ohiostiva made me realize, something isn't all right with mine, while other's were quiet as can be, mine would make a racket while idling.
Karl briefly took a listen, mentioned something about possibly being valves.
Now the PO did tell me this engine is from an 89', but I have no clue whether it was from an 89' Auto, or Manual. So I don't know if it has the solid lifters, or hydraulic. Now I assumed it was hydraulic because I would occasionally get lifter tick on startup, but would go away after about a minute of running, and I think only hydraulic lifters do that.
Also I have never touched the timing on the car, since I have never found anyone with a timing light, but I don't think timing has anything to do with this.
I will try and record the engine noise, but it probably won't be all that clear.
