Hi all!
Engine 1.3, EFI
When the engine is warm, it sometimes happens that floats idling. All consumers disconnected.
I guess that the reason is an air leak, or a bad vacuum line. Or somewhere clogged.
The question itself that is usually the cause of floatingidle, which is in the first place to check.
As far as I know, there is no idle valve, and the air flow is regulated at idle I do not know.
Thanks!
Engine 1.3, EFI
Thanks!
