PCV Valve Housing Removal and Installation
  • PCV Valve Housing Removal and Installation
    Anybody have any information on how to safely remove the PCV Valve housing and install it without ripping it in half? Any help is appreciated!
    Are you talking about the grommet?
    Its easiest with the VC off. I have done it from above before, stick a small screwdriver down one side of the grommet and push it over till the "O" loocs like a "C", then pinch both sides together and try to wiggle it out. If the rubber is old/brittle it will crack.
    ~Nate
    Current cars:
    FOTY 2008 winner!
      Exactly as stated above. You might want to practice, at a JY, on expendable units first. They do tend to get brittle with age. If bits of debris falls inside the cover (should you not have removed the valve cover) you don't have to worry too much: there is an enclosed plate underneath that makes sure there isn't a direct drop into the valves and rockers.
