My dad has my 91 Festiva now but it's still having the problem I thought I fixed 6 months ago. When you go to start it the fan runs even though it's cold. I used to be able to unplug the fan and it would work. It takes about 3-5 tries before it will start and stay started, but it has started dying on the highway. He's stopped driving it because of that, can't blame him. He loves the car though, lighter and has a little bit more power than this 91.
I have replaced the temp sensor twice, replaced the relay, switched fans, redid the connections to no avail. I'm going to test the temp sensor again with the multimeter which is probably the problem. But why would the sensor's be going out? Unless I managed to get two bad ones. It dieing is what I find odd it never did that when I had it.
Everything maintenance wise is in tip-top shape. New wires, spark plugs and all filters. Although i'm going to test the spark plug wires just in case. I know a couple others had this problem but I don't if anyone ever figured it out. I would just do the toggle switch but that's not going to help the starting problem it seems. Suggestions anyone?
