91 GL oil leak 1 quart per 500-1000k
Oil is leaking onto my belts, looks like it coming from main crnk seal in front. I havent pulled the timing cover yet, this engine has had top end rebuild about 10k but lower end not done, im assuming crank. Problem is its leaking onto my v belt and has thrown it twice. I want a easy fix if possible, do you have suggestions? I was thinking slap some sort of liqiud gasket substance around area. Im going to replace the timing belt if i take cover off, ill be in the area anyways.
Im fixing my other festy waiting to find aspire for swap and until then this one has to last, im going to swap motor once other festy is up amd running so i need a quick fix. Thanks in advance.
put back together.
