Not really a repair help, but more of a question leading to beneficial answers for this project.
Anyways, is it possible to run two batteries in a festiva? Off the same alternator?
I currently have a redtop, and during these cold Canadian months, it seems to be lacking in the crank amps department. Could be that its 4 years old, but its still starting the same as it always has.
My question is more for accessories to lessen the cranking amps on the main battery.
Suppose I put a battery in the rear and run a cable from the alternator, through the fire wall to behind my seat. I'd ultimately put a cut off so that I know not to blow it up. But my plan, if possible, is to runs battery behind the seat, grounded to the seat bolt, that I could run my amp, and subwoofer and other accessories off of.
Has anyone done this? Is it eve possible? Can our alternators handle it?
I'm currently 1st gen 323 swapped. Thanks for the help dudes!
-James
-James
