Any tried and true methods? anyone find the most likely culprits to this with a solution? mine closes solid, just a bunch of high pitched squeaking...
Ridiculous hatch rattling
I've always had the same problem, never been able to really nail it down, but I can only figure the latch itself is worn.89 LX (461xxx miles original motor and trans, retired
90 L (restoration in progress)
91 L (saved from abusive owner lol)
92 L (DD)
88 (model unknown, rust free, possible project)
88-89 (parts car. practically picked to the bone)
93 GL (parts car)
that may work for him, I tried it on mine both the hatch latch and the hood latch pins are worn more than half way through on my car, I have spares, just don't ever think about it till I am driving down the road and the rattling is driving me nuts :tard:Originally posted by denguy View PostThose hatch latches are adjustable. You can loosen the mounting screws and move the latch around. Might help.Last edited by mystro; 11-27-2013, 09:50 AM.89 LX (461xxx miles original motor and trans, retired
92 L (DD)
93 GL (parts car)
Sometimes you can cut a very small hole in the weatherstripping and feed a narrow length of vacuum hose in there. Just use a little bit of silicone grease and feed it through until it gets all the way around the seal.
This helps to "thicken" and bulk up the seal for a tighter fit.
My previous aspire had hatch rattling from the subwoofer in the trunk.
So I adjusted the hatch latch to tighten up the slack.
And it never rattled again.
Also it shut nice and tight.
Make sure the hatch lock has a thin rubber gasket around the lip of the bezel and that the inner spring retainer clip has good tension.Last edited by bravekozak; 11-28-2013, 09:24 AM.
I did what you are suggesting with the doors, yesterday I went to the hardware store and bought some cord and put it around the door seal, the wind noise was greatly reduced.Originally posted by MasterTec View PostSometimes you can cut a very small hole in the weatherstripping and feed a narrow length of vacuum hose in there. Just use a little bit of silicone grease and feed it through until it gets all the way around the seal.
This helps to "thicken" and bulk up the seal for a tighter fit.An idea can turn to dust or magic, depending on the talent that rubs against it.
I use my hatch door about 10 times daily it will cut right thru. I do remember doing that to my foxbody Mustang because the plastic outer ring will split on those1993 GL 5 speed
