I posted this in my existing post but I wanted to make sure folks see it so I can possibly get some help with this. I was wanting to burp the coolant system and I started to pour in the antifreeze when I hear a steady stream hitting the ground. In the picture is where the hole is, right on the bottom of the smaller tube right before it goes into the flared end.
I was thinking I could possible cut the section before the hole and the section after the flared part and get a piece of tubing of some sort and clamping it on both ends. Would this possibly work? What type of tube should I buy to try this? Thanks for any help. Jim
