Hey guys, just a quick question. When I start my car every time the belt squeals like crazy for a bit. Usually it squeals longer if i turn on the heat or even the headlights. Another problem is that when im driving it will randomly start squealing. Also sometimes when i push the brakes in it starts squealing and the lights will dim. Anyone have any solutions? Thanks in advance!
squealing belt
My car did this last year. Same exact symptoms. Turned out to be the altanator1990 Red Festiva STOCK "pregnant roller skate"
1989 Yellow Festiva BP swap "Freebird"
2007 Ford F150 "black sunshine" full exhaust with x-pipe. K&N intake. Headman Headers.
2001 Honda accord SOLD lots of goodies done suicide doors lowered 20 inch rims
2005 Ford F250 6.0 Turbo Diesel "swamprat" 4 inch lift, 4 inch mbrp exhaust, egr delete, glowshift pillar gauges.
1994 Ford F150 5.0 Completely stock.
Alternator bearings do eventually wear out too.
But hopefully it is a lose belt.
Do you have the wide serpentine type belt or the v-belt?
If it's not the regular v belt, I'm not familiar with how the serpentine one on the Aspire is tightened.
Aspire belts aren't serpentine, but they are different. They are ribbed instead of V-shaped, and tighten the same way as Festy belts. I have used a prybar too, for leverage to get it tight enough. I find that a really long flat-blade screwdriver would also do the trick, and is easier to fit in there.90 Festy (Larry)--B6M (Matt D. modified B6 head), header, 5-speed, Capri XR2 front brakes, many other little mods
Going through this same thing with my daughter's Festie. Can anyone say if there is anything other than price difference between a $5 new belt and a $10 new belt? Also, if it is an alternator (our issue) does anyone know where to find a reman alternator for less than $100?
^ IS it the Alt? have you checked the bearings and charging voltage? WARNING: a slipping belt can cause low charging voltage.
as far as the price of belts, typicaly the $$ belt has a better grade of rubber and is designed to be more flexable for longer life, but even low grade belts last for years nowadaysTrees aren't kind to me...
Changed the belt. $4.99 at Autozone. Belt that came off the car looked like it was original. Cracked, missing teeth, shiney.. I really don't know how it was working.
All in all, it took about about 7 minutes to change the belt, but I had a tough time getting the new belt on. Had to struggle to get it on, but it fit perfect into the groove and no more squeeling!!!
Yea for a $5 repair.
