Could some one please advise the location of the timing cover white mark - wb festiva
Timing Cover mark
Yeah, I can't seem to find any marks either, on the pulley or timing cover.
Sent from my SPH-M950 using Tapatalk1991 Ford Festiva BP (Full Aspire/Rio Swap) (337k Miles) (Around 95k Engine)
If you make sure the cam timing marks are at 12&3 and the #1 piston is tdc the mark should be at the 12 o'clock on the crank pulley iirc, it will at least be up where you should see it.2008 Kia Rio- new beater
1993 Festiva- Fiona, DD
1997 Aspire- Babyspire, DD
1994 Aspire - Project Kiazord
1994 Aspire- Crustyspire, RIP
