will rack from 93 aspire fit 89 festiva?
  • will rack from 93 aspire fit 89 festiva?
    both racks are aluminum.
    thanks
    admit nothing - deny everything - make accusations
    I don't see why it wouldn't, they're nearly the same width.
    As far as the feet working, that may be an issue. But, most racks feet are the same, and if its not vehicle specific (as in factory stock) it should work just fine.
    Is it a factory rack? Or aftermarket?
    -James
    Est. 1989 "Bringing laughter and festiva awesomeness to the world since birth" banana time
      yes they will but get the brackets with the rack
        94 is the first year on the aspire.
          both the racks are factory. the Aspire is a 94.
            If they're factory racks, I'd say maybe. You do, however, have to drill holes in your roof if I'm not mistaken...(?)
            -James
              Roof rack or steering rack? Steering rack will definitely work, use the appropriate tie rods for the vehicle. Roof rack absolutely will not swap. The aspire roof is completely and totally different from a Festiva roof.
              /e if you want to bolt it on just to prove me wrong feel free but I wouldn't drive it with 1/2" gaps between the feet and the sheet metal.
              2008 Kia Rio- new beater
              1993 Festiva- Fiona, DD
              1997 Aspire- Babyspire, DD
              1994 Aspire - Project Kiazord
              1994 Aspire- Crustyspire, RIP
                I didn't even pay attention to the fact that this was about steering rack. My bad.
                -James
                  -James
                  That was awesome.
                    Use inner tie rods from Festiva and whatever outer tie rods for the steering knuckles you are using.
                    1993 Festiva L "Wendy" BP n' stuff
                    2013 Mazdaspeed 3 "The Kraken" -Stock.
                    Dave Forget
                      this is great... about to do the same thing this week.
