i think i'm burning and/or leaking oil
  • i think i'm burning and/or leaking oil
    i'm loosing oil faster then i can give it to the car, yet i don 't detect very much of an oil leak.... need to to find the problem and stop it anybody have this problem? the size of the puddle of oil looks as it it could leak for two months before i have to add oil, yet i have to about 1/2 a quart of oil about every third time or so times i drive.....
    Doug's Daily Driver (Dad): '91 Ford Festiva L Manual "Old Yellow" got with 40,xxx mi... about 52,xxx mi. give or take now
    Austin's Daily Driver (mine) : '91 Ford Festiva GL Automatic "Whitie III" W/ 0.40 over aspire engine from '94 Aspire "New Blue" rebuilt 92,xxx mi. then... about 96,xxx mi. or more now (on body)
    Doug's work car: '95 Ford Aspire Manual "Whitie II" w/ swapped stock aspire engine from '95 Silver Aspire and has
    it's 5th transmission! 75,xxx mi... now with about 130,xxx mi.
    Sold! '89 Ford Festiva Manual "Gaystiva" (sold to my Uncle) - got with 163,xxx..... now 163,xxx Sold!
    TRANSFERRED! '89 Ford Festiva Automatic EFI "one hit wonder" Given to
    bolokid - got with 210,xxx ...... now with 210,xxx miles TRANSFERRED!
    '94 Ford Aspire SE Manual "Assfire" - got with at least 350,000 mi
    SOLD! '90 Ford Festiva L Manual look for Narion (or click the username) it's new owner on the forum! - got with 193,xxx miles... now has 193,xxx miles give or take SOLD!
    R.I.P '91 Ford Escort GT w/ bad engine..... stripping for parts then off to the scrapper!
    R.I.P '91 Ford Festiva Manual "Lil Red Rocket" bought brand new in 1991 with ~120 mi... ended with 227,xxx mi.
    R.I.P '97 Ford Aspire 4 Door Automatic "Ford Metro" parts car - got with about 144,xxx mi.... ended with 144,xxx mi
    R.I.P '95 Ford Aspire Manual Silver (one owner and one family car) got with about 50,000 miles ended with about 90,000 miles
    R.I.P '94 Ford Aspire Manual "New Blue" got with 150,xxx.... ended with about 200,xxx (it's engine is the .40 engine in my GL)
    Have you noticed any smoke?
    Jerry
    Team Lightning
    Owner of Team Lightning
    93 L Lightning. BP
      yes but it just looks like steam to me... white like steam but not thick usually when warm
        Could be bad rings unfortunately. If there's oil in your coolant then your in luck and all you need is a new head gasket.
        1993 Festy, 1.6SOHC, Aspire Suspension
        Stripped to bare bones, SCCA RallyX
          Nothing wrong with a little upper cylinder lubricant.
          Sent from my rooted HTC Supersonic using Tapatalk 2 Pro
            You can change pcv maybe its clogged and pressurr is building inside. That system is ismore important then i initially thought.
            Yellow 91 festiva GL 5speed
            Red 88festiva L 4spd
            Blue 91festiva L 5spd (bad tranny, sloppy suspension)
              no coolant in my oil
                Get that car on flat ground. Check it the same way every time overnight sitting. I have a really small incline on my driveway. It reads down .8L at home, and overfull at my moms in the street! You might not be as bad as you think!
                On a positive note, these cars run OK overfull and down a quart too. Dont do either but they are survivors either way.
                1993 GL 5 speed
