88 festiva LX (carb) 225k miles.
On a cold start (less than 25 degrees F outside temp) the car starts fine. It runs for about 15 seconds perfectly fine, then starts misfiring on one cylinder. I can let it sit and idle for several minutes and it will continue to misfire. If I jab the throttle a few times, it goes away. If I let it go for more than a few seconds before I jab the gas, when I finally do it blows oil smoke out the exhaust (I assume just from one cylinder not igniting). I can't wrap my head around what causes this. No misfire at any other time. beyond this small annoyance, it runs perfectly except for some valve ticking (I havent mastered the art of valve adjustments yet).
I am thinking maybe a fuel pump or carb issue, but not sure why it would only happen on cold weather.
Any idea what might cause this? I dont want to throw money at things so I need some logic involved other than just "replace the spark plugs" Thanks all!
